This page provides address range settings used in IPMC profile. The address entry is used to specify the address range that will be associated with IPMC Profile. It is allowed to create at maximum 128 address entries in the system.
Object | Description |
Delete | Check to delete the entry. The designated entry will be deleted during the next save. |
Entry Name | The name used for indexing the address entry table. Each entry has the unique name which is composed of at maximum 16 alphanumeric characters. At least one alphabet must be present. |
Start Address | The starting IPv4/IPv6 Multicast Group Address that will be used as an address range. |
End Address | The ending IPv4/IPv6 Multicast Group Address that will be used as an address range. |
Buttons | |
Add a new address range. Specify the name and configure the addresses. |
Save changes. |
Undo any changes and revert to previously saved values. |
Refresh the page immediately. Any non-committed changes will be lost. |
Update the table starting from the first entry in the table. |
Update the table starting with the entry after the last entry currently displayed. |
