RMON History
Configure RMON History table on this page. The entry index key is ID.
Object Description
Delete Check to delete the entry. It will be deleted during the next save.
ID Indicates the index of the entry. Valid values are 1 – 65535.
Data Source Indicates the port ID which wants to be monitored. If in stacking switch, the value must add 1000*(switch ID – 1). For example, if the port is switch 3, port 5, the value is 2005.
Interval Indicates the interval in seconds for sampling the history statistics data. Valid range is 1 – 3600. Default value is 1800 seconds.
Buckets Indicates the maximum data entries associated this History control entry stored in RMON. Valid range is 1 – 3600. Default value is 50.
Buckets Granted The number of data shall be saved in the RMON.
Buttons
Add a new entry.
Save changes.
Undo any changes and revert to previously saved values.
