This page allows you to configure the RADIUS servers.
Object | Description |
Global Configuration | |
Timeout | Timeout is the number of seconds (1 – 1000), to wait for a reply from a RADIUS server before retransmitting the request. |
Retransmit | Retransmit is the number of times (1 – 1000) a RADIUS request is retransmitted to a server that is not responding. If the server has not responded after the last retransmit it is considered to be dead. |
Deadtime | Deadtime (0 – 1440 minutes) is the period during
which the switch will not send new requests to a server that has failed to
respond to a previous request. This will stop the switch from continually
trying to contact a server that it has already determined as dead. Setting the Deadtime to a value greater than 0 (zero) will enable this feature, but only if more than one server has been configured. |
Key | The secret key—up to 63 characters long—shared between the RADIUS server and the switch. |
NAS-IP-Address(Attribute 4) | The IPv4 address to be used as attribute 4 in RADIUS Access-Request packets. If this field is left blank, the IP address of the outgoing interface is used. |
NAS-IPv6-Address(Attribute 95) | The IPv6 address to be used as attribute 95 in RADIUS Access-Request packets. If this field is left blank, the IP address of the outgoing interface is used. |
NAS-Identifier (Attribute 32) | The identifier (up to 253 characters long) to be used as attribute 32 in RADIUS Access-Request packets. If this field is left blank, the NAS-Identifier is not included in the packet. |
Server Configuration | |
Delete | To delete a RADIUS server entry, check this box. The entry will be deleted during the next Save. |
Hostname | The IP address or hostname of the RADIUS server. |
Auth Port | The UDP port to use on the RADIUS server for authentication. |
Acct Port | The UDP port to use on the RADIUS server for accounting. |
Timeout | This optional setting overrides the global timeout value. Leaving it blank will use the global timeout value. |
Retransmit | This optional setting overrides the global retransmit value. Leaving it blank will use the global retransmit value. |
Key | This optional setting overrides the global key. Leaving it blank will use the global key. |
Buttons | |
Add a new server. Up to five servers are supported. |
Delete the setting. |
Save changes. |
Undo any changes and revert to previously saved values. |
