You can inspect the current status for all PoE ports on this page.
Object | Description |
PoE Status | |
Local Port | This is the logical port number for this row. |
PD Class | Each PD is classified according to a class that
defines the maximum power the PD will use. The PD Class shows the PDs
class. Five Classes are defined:
Power Requested | The Power Requested shows the requested amount of power the PD wants to be reserved. |
Power Allocated | The Power Allocated shows the amount of power the switch has allocated for the PD. |
Power Used | The Power Used shows how much power the PD currently is using. |
Current Used | The Power Used shows how much current the PD currently is using. |
Priority | The Priority shows the port's priority configured by the user. |
Port Status | The Port Status shows the port's status. The status
can be one of the following:
Buttons | |
Refresh the page automatically every three seconds. |
Refresh the page immediately. Any non-committed changes will be lost. |
