Each page shows up to 99 entries from the Dynamic DHCP snooping table, default being 20, selected through the entries per page input field. When first visited, the web page will show the first 20 entries from the beginning of the Dynamic DHCP snooping Table.
The MAC address and VLAN input
fields allow you to select the starting point in the Dynamic DHCP snooping Table.
Clicking the Refresh button will update the
displayed table starting from that or the closest next Dynamic DHCP snooping Table
match. In addition, the two input fields will, upon a Refresh
button click, assume the value of the first displayed entry, allowing for continuous
refresh with the same start address.
The will use the last entry of the
currently displayed table as a basis for the next lookup. When the end is reached,
No more entries shows in the displayed table. Use the
button to start over.
Object | Description |
MAC Address | User MAC address of the entry. |
VLAN ID | VLAN-ID in which the DHCP traffic is permitted. |
Source Port | Switch Port Number for which the entries are displayed. |
IP Address | User IP address of the entry. |
IP Subnet Mask | User IP subnet mask of the entry. |
DHCP Server Address | DHCP Server address of the entry. |
Buttons | |
Refresh the page automatically every three seconds. |
Refresh the page immediately. Any non-committed changes will be lost. |
Clear all statistics or dynamic entries. |
Update the table starting from the first entry in the table. |
Update the table starting with the entry after the last entry currently displayed. |
