This page manages DHCP pools. According to the DHCP pool, DHCP server will allocate IP address and deliver configuration parameters to DHCP client.
Object | Description |
Name | Configure the pool name that accepts all printable characters, except white space. If you want to configure the detail settings, you can click the pool name to go to the Configuration page. |
Type | Displays the pool type:
IP | Displays network number of the DHCP address pool. If “-” is displayed, the IP is not defined. |
Subnet Mask | Displays subnet mask of the DHCP address pool. If “-” is displayed, the subnet mask is not defined. |
Lease Time | Displays lease time of the pool. |
Buttons | |
Delete the setting. |
Add a new DHCP pool. |
Save changes. |
Undo any changes and revert to previously saved values. |
