Configure SNMPv3 user table on this page. The entry index keys are Engine ID and User Name.
Object | Description |
Delete | Select to delete the entry. It will be deleted during the next save. |
Engine ID | An octet string identifying the engine ID that this
entry should belong to. The string must contain an even number (in
hexadecimal format) with 10 – 64, but all zeros and all Fs are not allowed.
The SNMPv3 architecture uses the User-based Security Model (USM) for message security and the View-based Access Control Model (VACM) for access control. For the USM entry, the usmUserEngineID and usmUserName are the entry's keys. In a simple agent, usmUserEngineID is always that agent's own snmpEngineID value. The value can also take the snmpEngineID value of a remote SNMP engine with which this user can communicate. In other words, if the user engine ID equals the system engine ID, then it is local user; otherwise it is remote user. |
User name | A string identifying the user name that this entry should belong to. Valid string length is 1 – 32, and the allowed content is ASCII characters 33 – 126. |
Security Level | Indicates the security model that this entry should
belong to. Possible security models are:
Note: Ensure that the value is set correctly because it
cannot be modified if an entry already exists.
Authentication Protocol | Indicates the authentication protocol that this entry
should belong to. Possible authentication protocols are:
Authentication Password | A string identifying the authentication password phrase. For MD5 authentication protocol, valid string length is 8 – 32. For SHA authentication protocol, valid string length is 8 – 40. The allowed content is ASCII characters 33 – 126. |
Privacy Protocol | Indicates the privacy protocol that this entry should belong to. Possible privacy protocols are:
Privacy Password | A string identifying the privacy password phrase. Valid string length is 8 – 32, and the allowed content is ASCII characters 33 – 126. |
Buttons | |
Add a new entry. |
Save changes. |
Undo any changes and revert to previously saved values. |
