Delete |
Check to delete the entry. It will be deleted during the next save. |
ID |
Indicates the index of the entry. Valid values are 1 – 65535. |
Desc |
Indicates this event. Valid string length is 0 – 127. Default is a null string. |
Type |
Indicates the notification of the event, the possible types are:
- none: No SNMP log is created, no SNMP
trap is sent.
- log: Create SNMP log entry when the event is triggered.
- snmptrap: Send SNMP trap when the event is triggered.
- logandtrap: Create SNMP log entry and sent SNMP trap when the event is triggered.
Community |
Specify the community when trap is sent. Valid string length is 0 – 127. Default is public. |
Event Last Time |
Indicates the value of sysUpTime at the time this event entry last generated an event. |
