DSCP-Based QoS
This page allows you to configure the basic QoS DSCP based QoS Ingress Classification settings for all switches.
Object Description
DSCP Maximum number of supported DSCP values are 64.
Trust Controls whether a specific DSCP value is trusted. Only frames with trusted DSCP values are mapped to a specific QoS Class and DPL (Drop Precedence Level). Frames with untrusted DSCP values are treated as a non-IP frame.
QoS Class QoS class value can be any of (0 – 7).
DPL Drop Precedence Level (0 – 1).
Buttons
Save changes.
Undo any changes and revert to previously saved values.
