This page configures excluded IP addresses. DHCP server will not allocate these excluded IP addresses to the DHCP client.
Object | Description |
IP Range | Define the IP range to be excluded IP addresses. The first excluded IP must be smaller than or equal to the second excluded IP. However, if the IP range contains only one excluded IP, you can input it to either one of the first and second excluded IP, or both. |
Buttons | |
Delete the setting. |
Add a new excluded IP range. |
Save changes. |
Undo any changes and revert to previously saved values. |
