Access Management
Configure access management table on this page. The maximum number of entries is 16. If the application's type match any one of the access management entries, it will allow access to the switch.
Object Description
Mode Indicates the access management mode operation. Possible modes are:
  • Enabled: Enable access management mode operation.
  • Disabled: Disable access management mode operation.
Delete Check to delete the entry. It will be deleted during the next save.
VLAN ID The VLAN ID for the access management entry.
Start IP address The start IP address for the access management entry.
End IP address The end IP address for the access management entry.
HTTP/HTTPS The host can access the switch from HTTP/HTTPS interface if the host IP address matches the IP address range provided in the entry.
SNMP The host can access the switch from SNMP interface if the host IP address matches the IP address range provided in the entry.
TELNET/SSH The host can access the switch from TELNET/SSH interface if the host IP address matches the IP address range provided in the entry.
Buttons
Add a new entry.
Save changes.
Undo any changes and revert to previously saved values.
