SNMP Access
Configure SNMPv3 access table on this page. The entry index keys are Group Name, Security Model and Security Level.
Object Description
Delete Check to delete the entry. It will be deleted during the next save.
Group Name A string identifying the group name that this entry should belong to. The allowed string length is 1 to 32, and the allowed content is ASCII characters from 33 to 126.
Security Model Indicates the security model that this entry should belong to. Possible security models are:
  • any: Any security model accepted (v1|v2c|usm)
  • v1: Reserved for SNMPv1
  • v2c: Reserved for SNMPv2c
  • usm: User-based Security Model (USM)
Security Level Indicates the security model that this entry should belong to. Possible security models are:
  • NoAuth, NoPriv: No authentication and no privacy.
  • Auth, NoPriv: Authentication and no privacy.
  • Auth, Priv: Authentication and privacy.
Read View Name The name of the MIB view defining the MIB objects for which this request may request the current values. Valid string length is 1 – 32, and the allowed content is ASCII characters from 33 – 126.
Write View Name The name of the MIB view defining the MIB objects for which this request may potentially set new values. Valid string length is 1 – 32, and the allowed content is ASCII characters from 33 – 126.
Buttons
Add a new entry.
Save changes.
Undo any changes and revert to previously saved values.
