Port |
The port number for which the configuration below applies. |
Enabled |
Controls whether the policer is enabled on this switch port. |
Rate |
Controls the rate for the policer. The default value is 500. This value is restricted to 100 – 1000000 when the “Unit” is “kbps” or “fps”, and it is restricted to 1 – 3300 when the “Unit” is “Mbps” or “kfps”. |
Unit |
Controls the unit of measure for the policer rate as kbps, Mbps, fps or kfps . The default value is “kbps”. |
Flow Control |
If flow control is enabled and the port is in flow control mode, then pause frames are sent instead of discarding frames. |
