This page provides power scheduling configurations. The entry is used to control the power alive interval on PoE port. It is allowed to set the specific interval to schedule power on/off in one week.
Object | Description |
Power Scheduling Interval Configuration | |
Day | Checkmarks indicate which day are members of the set. |
Interval |
Start - Select the start hour and minute. End - Select the end hour and minute. |
Action |
Power On - Select the radio button to apply power on during the interval. Power Off - Select the radio button to apply power off during the interval. |
Power Scheduling During | |
Time Interval | There are 48 time intervals in one day and each interval has 30 minutes. |
Day | The current scheduling state is displayed graphically during the week. Green indicates the power is on and red that it is off. Directly changes checkmarks to indicate which day are members of the time interval. Check or uncheck as needed to modify the scheduling table. |
Buttons | |
Apply the configuration. For PoE, apply the scheduling interval. |
Save changes. |
Undo any changes and revert to previously saved values. |
