Storm control for the switch is configured on this page.
There is a unicast storm rate control, multicast storm rate control, and a broadcast storm rate control. These only affect flooded frames, that is, frames with a (VLAN ID, DMAC) pair not present on the MAC Address table.
The configuration indicates the permitted packet rate for unicast, multicast or broadcast traffic across the switch.
Object | Description |
Frame Type | The settings in a particular row apply to the frame type listed here: Unicast, Multicast or Broadcast. |
Enable | Enable or disable the storm control status for the given frame type. |
Rate | The rate unit is packets per second (pps). Valid values are: 1, 2, 4, 8, 16, 32, 64, 128, 256, 512, 1K, 2K, 4K, 8K, 16K, 32K, 64K, 128K, 256K, 512K or 1024K. |
Buttons | |
Save changes. |
Undo any changes and revert to previously saved values. |
