This page allows you to configure the basic GVRP Configuration settings for all switch ports.
Object | Description |
GVRP Protocol timers | Join-time is a value (range 1 – 20) in the units of centiseconds; that is, in units of one hundredth of a second. The default is 20. Leave-time is a value in the range 60 – 300 in the units of centiseconds, The default is 60. LeaveAll-time is a value in the range 1000 – 5000 in the units of centiseconds. The default is 1000. |
Max number of VLANs | When GVRP is enabled a maximum number of VLANs supported by GVRP is specified. Default is 20. This number can only be changed when GVRP is turned off. |
Buttons | |
Refresh the page immediately. Any non-committed changes will be lost. |
Save changes. |
