This page shows the ACL status by different ACL users. Each row describes the ACE that is defined. It is a conflict if a specific ACE is not applied to the hardware due to hardware limitations. The maximum number of ACEs is 256 on each switch.
Object | Description |
User | Indicates the ACL user. |
Ingress Port | Indicates the ingress port of the ACE. Possible values are:
Frame Type | Indicates the frame type of the ACE. Possible values are:
Action | Indicates the forwarding action of the ACE.
Rate limiter | Indicates the rate limiter number of the ACE. Valid range is 1 – 16. When Disabled is displayed, the rate limiter operation is disabled. |
Port Redirect | Indicates the port redirect operation of the ACE. Frames matching the ACE are redirected to the port number. The allowed values are Disabled or a specific port number. When Disabled is displayed, the port redirect operation is disabled. |
Mirror | Specify the mirror operation of this port. The
allowed values are:
The default is Disabled. |
CPU | Forward packet that matched the specific ACE to CPU. |
CPU Once | Forward first packet that matched the specific ACE to CPU. |
Counter | The counter indicates the number of times the ACE was hit by a frame. |
Conflict | Indicates the hardware status of the specific ACE. The specific ACE is not applied to the hardware due to hardware limitations. |
Buttons | |
Refresh the page automatically every three seconds. |
Refresh the page immediately. Any non-committed changes will be lost. |
