This page allows you to add new protocols to Group Name (unique for each Group) mapping entries as well as allow you to see and delete already mapped entries for the switch.
The maximum possible Protocol to Group mappings are limited to 128.Object | Description |
Delete | Check this box to delete a Protocol to Group Name map entry. The entry will be deleted on the switch during the next Save. |
Frame Type | Frame Type can have one of the following values:
Note: On changing the Frame type field, valid value of
the following text field will vary depending on the new frame type you
selected.
Value | Valid value that can be entered in this text field depends on the option selected from the preceding Frame Type selection menu.
Below is the criteria for three different Frame Types:
Group Name | A valid Group Name is a unique 16-character long string for every entry which consists of alphanumeric characters (a-z or A-Z and 0-9). Note: Special characters and underscores (_) are not allowed.
Buttons | |
Refresh the page automatically every three seconds. |
Refresh the page immediately. Any non-committed changes will be lost. |
Undo the addition of the new entry or server. |
Add a new entry. |
Save changes. |
Undo any changes and revert to previously saved values. |
