Each page shows up to 99 entries from the Dynamic ARP Inspection table, default being 20, selected through the entries per page input field. When first visited, the web page will show the first 20 entries from the beginning of the Dynamic ARP Inspection Table.
The Start from port address, VLAN, MAC address, and IP address input fields allow you to select the starting point in the Dynamic ARP Inspection Table.
Clicking the Refresh button will update the displayed table starting from that or the closest next Dynamic ARP Inspection Table match. In addition, the two input fields will, upon a Refresh button click, assume the value of the first displayed entry, allowing for continuous refresh with the same start address.
The button will use the last entry of the currently displayed table
as a basis for the next lookup. When the end is reached, No more entries shows
in the displayed table. Use the
button to start
over.
Object | Description |
Port | Switch Port Number for which the entries are displayed. |
VLAN ID | VLAN-ID in which the ARP traffic is permitted. |
MAC Address | User MAC address of the entry. |
IP Address | User IP address of the entry. |
Buttons | |
Refresh the page automatically every three seconds. |
Refresh the page immediately. Any non-committed changes will be lost. |
Clear all statistics or dynamic entries. |
Update the table starting from the first entry in the table. |
Update the table starting with the entry after the last entry currently displayed. |
