ID |
Indicates the index of Statistics entry. |
Data Source(iflndex) |
The port ID which wants to be monitored. |
Drop |
The total number of events in which packets were dropped by the probe due to lack of resources. |
Octets |
The total number of octets of data (including those in bad packets) received on the network. |
Pkts |
The total number of packets (including bad packets, broadcast packets, and multicast packets) received. |
Broad-cast |
The total number of good packets received that were directed to the broadcast address. |
Multi-cast |
The total number of good packets received that were directed to a multicast address. |
CRC Errors |
The total number of packets received that had a length (excluding framing bits, but including FCS octets) of between 64 and 1518 octets, inclusive, but had either a bad Frame Check Sequence (FCS) with an integral number of octets (FCS Error) or a bad FCS with a non-integral number of octets (Alignment Error). |
Under-Size |
The total number of packets received that were less than 64 octets. |
Over-size |
The total number of packets received that were longer than 1518 octets. |
Frag. |
The number of frames which size is less than 64 octets received with invalid CRC. |
Jabb. |
The number of frames which size is larger than 64 octets received with invalid CRC. |
Coll. |
The best estimate of the total number of collisions on this Ethernet segment. |
64 |
The total number of packets (including bad packets) received that were 64 octets in length. |
65~127 |
The total number of packets (including bad packets) received that were 65 – 127 octets in length. |
128~255 |
The total number of packets (including bad packets) received that were 128 – 255 octets in length. |
256~511 |
The total number of packets (including bad packets) received that were between 256 – 511 octets in length. |
512~1023 |
The total number of packets (including bad packets) received that were 512 – 1023 octets in length. |
1024~1588 |
The total number of packets (including bad packets) received that were 1024 – 1588 octets in length. |
