VLAN ID |
The VLAN ID of the entry. |
Querier Version |
Working Querier Version currently. |
Host Version |
Working Host Version currently. |
Quereier Status |
Shows the Querier status is “ACTIVE” or “IDLE”.
“DISABLE” denotes the specific interface is administratively disabled. |
Queries Transmitted |
The number of Transmitted Queries. |
Queries Received |
The number of Received Queries. |
V1 Report Received |
The number of Received V1 Reports. |
V2 Report Received |
The number of Received V2 Reports. |
V1 Leaves Received |
The number of Received V1 Leaves. |
Router Port |
Display which ports act as router ports. A router port is a port on the Ethernet switch that leads towards the Layer 3 multicast device or MLD querier.
Static denotes the specific port is configured to be a router port.
Dynamic denotes the specific port is learnt to be a router port.
Both denote the specific port is configured or learnt to be a router port. |
Port |
Switch port number. |
status |
Indicate whether specific port is a router port or not. |
