This page provides MLD Snooping related configuration.
Object | Description |
Snooping Enable | Enable the Global MLD Snooping. |
Unregistered IPMCv6 Flooding Enable | Enable unregistered IPMCv6 traffic flooding. The flooding control takes effect only when MLD Snooping is enabled. When MLD Snooping is disabled, unregistered IPMCv6 traffic flooding is always active in spite of this setting. |
MLD SSM Range | SSM (Source-Specific Multicast) Range allows the SSM-aware hosts and routers run the SSM service model for the groups in the address range. |
Leave Proxy Enable | Enable MLD Leave Proxy. This feature can be used to avoid forwarding unnecessary leave messages to the router side. |
Proxy Enable | Enable MLD Proxy. This feature can be used to avoid forwarding unnecessary join and leave messages to the router side. |
Router Port | Specify which ports act as router ports. A router port is a port on the Ethernet switch that leads towards the Layer 3 multicast device or MLD querier. If an aggregation member port is selected as a router port, the whole aggregation will act as a router port. |
Fast Leave | Enable the fast leave on the port. |
Throttling | Enable to limit the number of multicast groups to which a switch port can belong. |
Buttons | |
Save changes. |
Undo any changes and revert to previously saved values. |
