System NTP
Configure NTP on this page.
Object Description
Mode Indicates the NTP mode operation. Possible modes are:
  • Enabled: Enable NTP client mode operation.
  • Disabled: Disable NTP client mode operation.
Server # Provide the IPv4 or IPv6 address of a NTP server. IPv6 address is in 128-bit records represented as eight fields of up to four hexadecimal digits with a colon separating each field (:). For example, fe80::215:c5ff:fe03:4dc7. The symbol :: is a special syntax that can be used as a shorthand way of representing multiple 16-bit groups of contiguous zeros; but it can appear only once. It can also represent a valid IPv4 address, such as ::192.1.2.34.
Buttons
Save changes.
Undo any changes and revert to previously saved values.
