Each page shows up to 99 entries from the IGMP SFM Information table, default being 20, selected through the entries per page input field. When first visited, the web page will show the first 20 entries from the beginning of the IGMP SFM Information Table.
The Start from VLAN and Group input fields allow you to select the starting point in the IGMP SFM Information Table. Clicking the Refresh button will update the displayed table starting from that or the closest next IGMP SFM Information Table match. In addition, the two input fields will, upon a Refresh button click, assume the value of the first displayed entry, allowing for continuous refresh with the same start address.
The will use the last entry of the
currently displayed table as a basis for the next lookup. When the end is reached,
No more entries shows in the displayed table. Use the
button to start over.
Object | Description |
VLAN ID | VLAN ID of the group. |
Group | Group address of the group displayed. |
Port | Switch port number. |
Mode | Indicates the filtering mode maintained per (VLAN ID, port number, Group Address) basis. It can be either Include or Exclude. |
Source Address | IP Address of the source. Currently, system limits the total number of IP source addresses for filtering to be 128. |
Type | Indicates the Type. It can be either Allow or Deny. |
Hardware Filter/Switch | Indicates whether data plane destined to the specific group address from the source IPv4 address could be handled by chip or not. |
Buttons | |
Refresh the page automatically every three seconds. |
Refresh the page immediately. Any non-committed changes will be lost. |
Update the table starting from the first entry in the table. |
Update the table starting with the entry after the last entry currently displayed. |
