Port Members |
Check the checkbox button to include the port in the QCL entry. By default all ports are included. |
Key parameters |
Key configuration is described as below:
- DMAC: Destination MAC address: Possible values are 'Unicast', 'Multicast', 'Broadcast', 'Specific' (xx-xx-xx-xx-xx-xx) or 'Any'.
- SMAC: Source MAC address: xx-xx-xx (24 MS bits OUI) xx-xx-xx-xx-xx-xx or 'Any'. If a port is configured to match on DMAC/DIP, this field is the Destination MAC address.
- Tag: Value of Tag field can be 'Untagged', 'Tagged', 'C-Tagged', 'S-Tagged' or 'Any'.
- VID: Valid value of VLAN ID can be any value in the range 1-4095 or 'Any'; user can enter either a specific value or a range of VIDs.
- PCP: Valid value PCP are specific (0, 1, 2, 3, 4, 5, 6, 7) or range (0-1, 2-3, 4-5, 6-7, 0-3, 4-7) or 'Any'.
- DEI Valid value of DEI can be '0', '1' or 'Any'.
Inner Tag Value of Inner Tag field can be 'Untagged', 'Tagged', 'C-Tagged', 'S-Tagged' or 'Any'.
Inner VID Valid value of Inner VLAN ID can be any value in the range 1-4095 or 'Any'; user can enter either a specific value or a range of VIDs.
Inner PCP Valid value of Inner PCP are specific (0, 1, 2, 3, 4, 5, 6, 7) or range (0-1, 2-3, 4-5, 6-7, 0-3, 4-7) or 'Any'.
Inner DEI Valid value of Inner DEI can be '0', '1' or 'Any'.
- Frame Type: Frame Type can have any of the following values:
- Any: Allow all types of frames.
- EtherType: Ether Type Valid Ether Type can
be 0x600-0xFFFF excluding 0x800(IPv4) and 0x86DD(IPv6) or
'Any'.
- LLC: SSAP Address Valid SSAP(Source Service
Access Point) can vary from 0x00 to 0xFF or 'Any'.
DSAP Address
Valid DSAP(Destination Service Access Point) can vary from 0x00
to 0xFF or 'Any'.
Control Valid Control field can vary from 0x00
to 0xFF or 'Any'.
- SNAP: PID Valid PID(a.k.a Ether Type) can be
0x0000-0xFFFF or 'Any'.
- IPv4: Protocol IP protocol number: (0-255,
'TCP' or 'UDP') or 'Any'.
Source IP Specific Source IP address
in value/mask format or 'Any'. IP and Mask are in the format
x.y.z.w where x, y, z, and w are decimal numbers between 0 and
255. When Mask is converted to a 32-bit binary string and read
from left to right, all bits following the first zero must also
be zero. If a port is configured to match on DMAC/DIP, this
field is the Destination IP address.
Destination IPSpecific
Destination IP address in value/mask format or 'Any'.
IP
Fragment IPv4 frame fragmented option: 'Yes', 'No' or
'Any'.
DSCP Diffserv Code Point value (DSCP): It can be a
specific value, range of values or 'Any'. DSCP values are in the
range 0-63 including BE, CS1-CS7, EF or AF11-AF43.
Sport Source
TCP/UDP port:(0-65535) or 'Any', specific or port range
applicable for IP protocol UDP/TCP.
Dport Destination TCP/UDP
port:(0-65535) or 'Any', specific or port range applicable for
- IPv6: Protocol IP protocol number: (0-255,
Source IP 32 LS bits of IPv6 source
address in value/mask format or 'Any'. If a port is configured
to match on DMAC/DIP, this field is the Destination IP
address.
Destination IP Specific Destination IP address in
(DSCP): It can be a specific value, range of values or 'Any'.
DSCP values are in the range 0-63 including BE, CS1-CS7, EF or
AF11-AF43.
Sport Source TCP/UDP port:(0-65535) or 'Any',
specific or port range applicable for IP protocol UDP/TCP.
Dport
Destination TCP/UDP port:(0-65535) or 'Any', specific or port
Action Parameters |
