ISW Series Managed Industrial Ethernet Switch Web Configuration Guide
Configuring the ISW Switch
ERPS
Configuring ERPS
> Configuring ERPS from the Web UI > Configuring ERPS on Switch 3
Published April 2022
Preface
Audience
Extreme Networks Documentation
Getting Help
Providing Feedback to Us
Introduction to the ISW Switch Web Interface
Logging in to the Web Interface
Navigating the Web Interface
System Information
System IP
System NTP
System Time
System Log
System Alarm Profile
Port Power Savings
Ports
DHCP Server Mode
DHCP Server Excluded IP
DHCP Server Pool
DHCP Snooping
DHCP Relay
Users
Privilege Level
Auth Method
SSH/Telnet
HTTPS
Access Management
SNMP System Configuration
SNMP Trap Configuration
SNMP Communities
SNMP Users
SNMP Groups
SNMP Views
SNMP Access
RMON Statistics
RMON History
RMON Alarm
RMON Event
Limit Control
NAS
ACL Ports
ACL Rate Limiters
Access Control List
IP Source Guard Static Table
ARP Inspection and Port Mode Configuration
VLAN Configuration
Static Table
Dynamic Table
Static Aggregation
LACP Aggregation
Loop Protection
Bridge Settings
MSTI Mapping
MSTI Priorities
CIST Ports
MSTI Ports
Profile Table
Address Entry
MVR
IGMP Snooping - Basic Configuration
IGMP Snooping - VLAN Configuration
Port Filtering Profile
MLD Snooping - Basic Configuration
MLD Snopping - VLAN Configuration
LLDP
LLDP-MED
PoE
PoE Scheduler
Power Reset
MEP
ERPS
Configuring ERPS
Configuring ERPS from the CLI
Initial Switch Configuration
Creating MEPs on Switch 1
Configuring MEPs on Switch 2
Configuring MEPs on Switch 3
Configuring ERPS on Switch 1
Configuring ERPS on Switch 2 (RPL Neighbor)
Verifying ERPS
MAC Table
VLANs
Private VLAN Membership
Port Isolation
MAC-based VLAN
Protocol to Group
Group to VLAN
IP Subnet-based VLAN
Voice VLAN Configuration
Voice VLAN OUI
Port Classification
Port Policing
Port Scheduler
Port Shaping
Port Tag Remarking
Port DSCP
DSCP-Based QoS
DSCP Translation
DSCP Classification
QoS Control List
Storm Control
Mirroring
Global Config
Port Config
RingV2
DDMI
Monitoring the ISW Switch
System Information
CPU Load
IP Status
System Log
System Detailed Log
System Alarm
Port Power Saving
Port State
Traffic Overview
QoS Statistics
QCL Status
Detailed Statistics
DHCP Server Statistics
DHCP Server Binding
DHCP Server Declined IP
DHCP Snooping Table
DHCP Relay Statistics
DHCP Detailed Statistics
Access Management Statistics
Network -- Port Security -- Switch Status
Network -- Port Security -- Port Status
NAS -- Switch Status
NAS -- Port State
ACL Status
ARP Inspection
RADIUS Overview
RADIUS Details
RMON Statistics
Alarm
Event
System Status
Port Status
Port Statistics
Loop Protection
Bridge Status
Port Status
Port Statistics
MVR Statistics
MVR Channel Groups
MVR SFM Information
IGMP Snooping - Status
IGMP Snooping - Groups Information
IGMP Snooping - IPv4 SFM Information
MLD Snooping - Status
MLD Snooping - Group Information
MLD Snooping - IPv6 SFM Information
Neighbors
LLDP-MED Neighbors
EEE
Port Statistics
PoE
MAC Table
VLANs Membership
VLANs Ports
MAC-Based VLAN
RingV2
DDMI Overview
DDMI Detailed
Ping
Diagnosing Switch Issues
Ping
Ping6
VeriPHY
Maintaining the ISW Switch
Restarting the Device
Resetting Factory Default
Software Upload
Image Select
Configuration
Save startup-config
Download Configuration
Upload Configuration
Activate Configuration
Delete Configuration
Regulatory and Compliance Information
From the web browser, navigate to
Configuration
ERPS
Click
Add New Protection Group
and configure the
ERPS
as shown below.
ERPS 1 on Switch 3
Edit ERPS1 by clicking 1 under the
ERPS ID
column.
Set the configuration as follows:
Set the
RPL Role
to
none
Click the
VLAN Config
link in the Instance Configuration table to add or edit the protected
(VLAN ID = 1).
Adding the Protected VLAN
Click
Configuring ERPS 1
Click
