Each page shows up to 99 entries from the MVR Group table, default being 20, selected through the entries per page input field. When first visited, the web page will show the first 20 entries from the beginning of the MVR Channels (Groups) Information Table.
The Start from VLAN and Group Address input fields allow you to select the starting point in the
MVR Channels (Groups) Information Table. Clicking the Refresh
button will update the displayed table starting from that or the closest next MVR
Channels (Groups) Information Table match. In addition, the two input fields will, upon
a Refresh button click, assume the value
of the first displayed entry, allowing for continuous refresh with the same start
address.
The will use the last entry of the currently displayed table as
a basis for the next lookup. When the end is reached, No more entries
shows in the displayed table. Use the
button to start over.
Object | Description |
VLAN ID | VLAN ID of the group. |
Groups | Group ID of the group displayed. |
Port Members | Ports under this group. |
Buttons | |
Refresh the page automatically every three seconds. |
Refresh the page immediately. Any non-committed changes will be lost. |
Update the table starting from the first entry in the table. |
Update the table starting with the entry after the last entry currently displayed. |
