The following table describes all the possible Alerts that are raised by Fault Management.
| Alert Name | Alert ID | Severity | Resource | Query Params | Param Values | |
| CertificateExpiryNoticeAlert | 31000 | Warning | /App/System/Security/Certificate | type | app_server_cert | |
| default_intermediate_ca | ||||||
| default_root_ca | ||||||
| third_party_ca | ||||||
| k3s_server_cert | ||||||
| k3s_ca | ||||||
| jwt_cert | ||||||
| DeviceCertificateExpiryNoticeAlert | 31001 | Warning | /App/System/Security/Certificate | device_ip | IP of the affected Device | |
| type | https_server_cert | |||||
| syslog_ca | ||||||
| jwt_verifier | ||||||
| CertificateExpiredAlert | 31002 | Critical | /App/System/Security/Certificate | type | app_server_cert | |
| DeviceCertificateExpiredAlert | 31003 | Critical | /App/System/Security/Certificate | device_ip | IP of the affected Device | |
| CertificateRenewalAlert | 31004 | Info | /App/System/Security/Certificate | type | app_server_cert | |
| jwt_cert | ||||||
| DeviceCertificateRenewalAlert | 31005 | Info | /App/System/Security/Certificate | device_ip | IP of the device | |
| CertificateUnreadableAlert | 31006 | |||||
| DeviceCertificateUnreadableAlert | 31007 | |||||
| LoginFailureAlert | 31010 | Major | /App/System/Security/Authentication | |||
| LoginSuccessfulAlert | 31011 | Info | /App/System/Security/Authentication | |||
| LDAPServerConnectivityFailureAlert | 31030 | Major | /App/System/Security/Authentication | server | LDAP Server IP address | |
| LDAPServerConnectivitySuccessAlert | 31031 | Info | /App/System/Security/Authentication | server | LDAP Server IP address | |
| LDAPServerConfigurationRemovedAlert | 31033 | info | /App/System/Security/Authentication | server | LDAP Server IP address | |
| StorageUtilizationThresholdAlert | 31040 | Warning | /App/System/Storage | node_ip | IP address of the node | |
| mount_point | Name of the mount point | |||||
| StorageUtilizationFullAlert | 31041 | Critical | /App/System/Storage | node_ip | IP address of the node | |
| StorageUtilizationCheckAlert | 31042 | Info | /App/System/Storage | node_ip | IP address of the node | |
| HAServiceNonRedundantAlert | 31050 | Major | /App/System/HA/Nodes/Node | |||
| HAServiceFullyRedundantAlert | 31051 | Info | /App/System/HA/Nodes/Node | |||
| HAServiceNewActiveAlert | 31052 | Info | /App/System/HA/Nodes/Node | |||
| HAServiceFailoverAlert | 31052 | Info | /App/System/HA/Services | |||
| ServiceDegradedAlert | 31053 | Major | /App/System/HA/Nodes/Services | |||
| ServiceRestoredAlert | 31054 | Info | App/System/HA/Nodes/Services | |||
| DeviceConnectivityFailureAlert | 31501 | Major | /App/Component/Asset/Device | device_ip | IP of the device | |
| DeviceConnectivitySuccessAlert | 31502 | Info | /App/Component/Asset/Device | device_ip | IP of the device | |
