network-property-add,
network-property-delete, and network-property-update
to add, delete, and update the network-property (NP) of an EPG networks. For
example, If an EPG doesn‘t have the NP MAC ACL applied and if you want to apply NP
MAC ACL on the EPG networks, then use the network-property-add or
network-property-update operation.
The network property configuration on Tenant EPG is supported only for PP ACL.efa tenant epg update --name <epg-name> --tenant <tenant-name>
--operation network-property-add
--switchport-native-vlan <2-4090> --l2-vni <ctag:l2-vni>
--ip-mtu <ctag:ip-mtu> --anycast-ip <ctag:anycast-ip> --anycast-ipv6 <ctag:anycast-ipv6
--bridge-domain <ctag:bridge-domain> --ctag-description <ctag:vlandescription>
--local-ip <ctag,device-ip:local-ip> --local-ipv6 <ctag,device-ip:local-ipv6>
--ipv6-nd-mtu <ctag:mtu> --ipv6-nd-managed-config <ctag:ipv6-nd-managed-config>
--ipv6-nd-other-config <ctag:ipv6-nd-other-config> --ipv6-nd-prefix <ctag:prefix1,prefix2
--ipv6-nd-prefix-valid-lifetime <ctag,prefix:validTime>
--ipv6-nd-prefix-preferred-lifetime <ctag,prefix:preferredTime>
--ipv6-nd-prefix-no-advertise <ctag,prefix:noadvertiseflag>
--ipv6-nd-prefix-config-type <ctag,prefix:configType>
--suppress-arp <ctag:suppress-arp>
--suppress-nd <ctag:suppress-nd>
--np-mac-acl-in <ctag:acl-name> --np-mac-acl-out <ctag:acl-name>
--np-ip-acl-in <ctag:acl-name> --np-ip-acl-out <ctag:acl-name>
--np-ipv6-acl-in <ctag:acl-name>
efa tenant epg update --tenant t1 --name epg2 --operation network-property-add
--np-mac-acl-in 360:ext-mac-permit-any-mirror-acl --np-ip-acl-in 360:ext-ip-permit-any-mirror-acl
efa tenant epg show --detail
Tenant : t1
Type : extension
State : epg-with-port-group-and-ctag-range
Description :
Ports : 10.20.246.15[0/35]
POs :
Port Property : SwitchPort Mode : trunk
: Native Vlan Tagging : false
: Single-Homed BFD Session Type : auto
NW Policy : Ctag Range : 360
: VRF : VRF11
: L3Vni : 15191
| MAC ACL IN | MAC ACL OUT | IP ACL IN | IP ACL OUT | IPv6 ACL IN |
Port Property ACLs
| Port | Dev State | App State |
| 10.20.246.15[0/35] | provisioned | cfg-in-sync |
Port Property States
|Ctag | Ctag |L2Vni |BD |Anycast |Anycast|Suppress| Local IP |IP MTU| IPv6 ND| IPv6 ND | IPv6 ND |Dev State |App State |
| | Description | |Name |IPv4 |IPv6 | ARP/ND |[Device-IP->| | MTU |Managed Config |Other Config | | |
| | | | | | | |Local-IP] | | | | | | |
|360 |Tenant L3 |11003 | |36.1.1.1/24 | | T/F | | | | false | false |provisioned|cfg-in-sync|
| |Extended VLAN | | | | | | | | | | | | |
Network Property [Flags : * - Native Vlan]
| Ctag | IPv6 ND Prefix | No Advertise | Valid Lifetime | Preferred Lifetime | Config Type |
IPv6 ND Prefix Flags
| Ctag| MAC ACL IN |MAC | IP ACL IN |IP | IPv6 |
| | |ACL OUT | |ACL OUT | ACL IN|
| 360 |ext-mac-permit-any-mirror-acl| |ext-ip-permit-any-mirror-acl| | |
Network Property ACLs
Rack1Device1# show run vlan 360 vlan 360 router-interface Ve 360 suppress-arp mac access-group ext-mac-permit-any-mirror-acl in description Tenant L3 Extended VLAN ! Rack1Device1# show run int ve 360 interface Ve 360 vrf forwarding VRF11 ip access-group ext-ip-permit-any-mirror-acl in ip anycast-address 36.1.1.1/24 no shutdown ! |
Rack1Device1# show run vlan 360 vlan 360 router-interface Ve 360 suppress-arp mac access-group ext-mac-permit-any-mirror-acl in description Tenant L3 Extended VLAN ! Rack1Device2# show run int ve 360 interface Ve 360 vrf forwarding VRF11 ip access-group ext-ip-permit-any-mirror-acl in ip anycast-address 36.1.1.1/24 no shutdown ! |
--operation network-property-delete
efa tenant epg update --tenant t1 --name epg2 --operation network-property-delete
Tenant : t1
Type : extension
Description :
POs :
: VRF : VRF11
: L3Vni : 15191
Port Property ACLs
|Ctag| Ctag |L2Vni |BD |Anycast IPv4|Anycast|Suppress| Local IP |IP |IPv6 | IPv6 ND | IPv6 ND | Dev State | App State |
| | Description | |Name| |IPv6 | ARP/ND |[Device-IP->Local-IP] |MTU|ND MTU|Managed Config|Other Config| | |
| |Extended VLAN| | | | | | | | | | | | |
| Ctag | MAC ACL IN | MAC ACL OUT | IP ACL IN | IP ACL OUT | IPv6 ACL IN |
For 'unstable' entities, run 'efa tenant po/vrf show' for detail
Rack1Device1# show run vlan 360 vlan 360 router-interface Ve 360 suppress-arp description Tenant L3 Extended VLAN ! Rack1Device1# show run int ve 360 interface Ve 360 vrf forwarding VRF11 ip anycast-address 36.1.1.1/24 no shutdown ! |
Rack1Device2# show run vlan 360 vlan 360 router-interface Ve 360 suppress-arp description Tenant L3 Extended VLAN ! Rack1Device2# show run int ve 360 interface Ve 360 vrf forwarding VRF11 ip anycast-address 36.1.1.1/24 no shutdown ! |
--operation network-property-update
efa tenant epg update --tenant t1 --name epg2 --operation network-property-update
--np-ip-acl-out 360:ext-ip-permit-any-mirror-acl --np-ipv6-acl-in 360:ext-ipv6-permit-any-mirror-acl
Tenant : t1
Type : extension
Description :
POs :
: VRF : VRF11
: L3Vni : 15191
Port Property ACLs
|Ctag | Ctag |L2Vni |BD Name |Anycast |Anycast IPv6 |Suppress| Local IP |IP |IPv6 ND| IPv6 ND | IPv6 ND | Dev State | App State |
| | Description | |Name |IPv4 |IPv6 | ARP/ND |[Device-IP->Local-IP] |MTU |ND MTU |Managed Config| Other Config| | |
|360 |Tenant L3 |11003 | |36.1.1.1/24| | T/F | | | | false | false |provisioned| cfg-in-sync|
|Ctag |MAC |MAC | IP | IP ACL OUT | IPv6 ACL IN |
| |ACL IN |ACL OUT | ACL IN| | |
|360 | | | | ext-ip-permit-any-mirror-acl |ext-ipv6-permit-any-mirror-acl |
For 'unstable' entities, run 'efa tenant po/vrf show' for details
Rack1Device1# show run vlan 360 vlan 360 router-interface Ve 360 suppress-arp description Tenant L3 Extended VLAN ! Rack1Device1# show run int ve 360 interface Ve 360 vrf forwarding VRF11 ip access-group ext-ip-permit-any-mirror-acl out ipv6 access-group ext-ipv6-permit-any-mirror-acl in ip anycast-address 36.1.1.1/24 no shutdown ! |
Rack1Device2# show run vlan 360 vlan 360 router-interface Ve 360 suppress-arp description Tenant L3 Extended VLAN ! Rack1Device2# show run int ve 360 interface Ve 360 vrf forwarding VRF11 ip access-group ext-ip-permit-any-mirror-acl out ipv6 access-group ext-ipv6-permit-any-mirror-acl in ip anycast-address 36.1.1.1/24 no shutdown ! |
