You can configure the maximum
transmission unit (MTU) when you create or update an endpoint group.
You use the --ip-mtu
parameter (in the format
ctag:value
) to configure the MTU for the tenant network. This
value is then configured on the interface VE on the SLX device.
To configure MTU when you create
an endpoint group, run the efa tenant epg create command.
$ efa tenant epg create --name ten1epg1 --tenant ten1 --port 10.20.246.17[0/1],
10.20.246.18[0/1] --switchport-mode trunk --ctag-range 11-12 --anycast-ip11:10.0.11.1/24
--anycast-ip12:10.0.12.1/24 --anycast-ipv6 11:11::1/127 --anycast-ipv6 12:12::1/127
--vrf ten1vrf1 --ip-mtu 11:7900 --ip-mtu 12:8900
This example creates an endpoint group with MTU values for Ctag 11 and Ctag
12.
To configure MTU for an existing
endpoint group, run the efa tenant epg update command during
vrf-add
or ctag-range-add
operations.
$ efa tenant epg update --name ten1epg1 --tenant ten1 --operation ctag-range-add
--ctag-range 12 --anycast-ip12:10.0.12.1/24 --anycast-ipv6 12:12::1/127 --ip-mtu 12:6990
This example configures the MTU during a ctag-range-add
operation.
To view the configured MTU for an endpoint group, run the efa tenant
epg show --detail command.
