You can use various commands and scripts to verify the status of the EFA system, to help troubleshoot, and to view details of EFA nodes, PODs, and services.
device# show efa status
EFA version details
Version : 3.1.0
Build: GA
Time Stamp: 22-11-10:17:11:29
Mode: Secure
Deployment Type: multi-node
Deployment Platform: TPVM
Deployment Suite: Fabric Automation
Virtual IP: 10.20.54.87
Node IPs: 10.20.54.88,10.20.54.89
Node IPv6s: ,
--- Time Elapsed: 9.30156ms ---
EFA Status
| Node Name | Role | Status | IP |
| node-1 | active | up | 10.20.54.88 |
| node-2 | standby | up | 10.20.54.89 |
--- Time Elapsed: 19.438967114s ---
On a multi-node installation:
+-----------+---------+--------+---------------+ | Node Name | Role | Status | IP | +-----------+---------+--------+---------------+ | tpvm2 | active | up | 10.20.216.242 | +-----------+---------+--------+---------------+ | tpvm1 | standby | up | 10.20.216.241 | +-----------+---------+--------+---------------+ --- Time Elapsed: 4.277420974s ---
On a single-node installation:
+-----------+--------+--------+-------------+ | Node Name | Role | Status | IP | +-----------+--------+--------+-------------+ | efa | active | up | 10.21.90.43 | +-----------+--------+--------+-------------+ --- Time Elapsed: 1.461512261s ---
(efa:extreme)extreme@node-1:~$ k3s kubectl get pods -n efa -o wide
NAME READY STATUS RESTARTS AGE IP NODE NOMINATED READINESS
NODE GATES
efa-api-docs-z84wn 1/1 Running 0 5h3m 10.42.194.72 efa <none> <none>
gosystem-service-t4h2b 1/1 Running 0 5h3m 10.42.194.74 efa <none> <none>
rabbitmq-vn27v 1/1 Running 0 5h4m 10.42.194.69 efa <none> <none>
goinventory-service-vpdj7 1/1 Running 0 5h3m 10.42.194.75 efa <none> <none>
goauth-service-g76c4 1/1 Running 0 5h3m 10.42.194.71 efa <none> <none>
gorbac-service-jzcnf 1/1 Running 0 5h3m 10.42.194.70 efa <none> <none>
gofaultmanager-service-wzwgp 1/1 Running 0 5h3m 10.42.194.73 efa <none> <none>
gotenant-service-qmvzb 1/1 Running 0 5h3m 10.42.194.78 efa <none> <none>
gonotification-service-h9ms2 1/1 Running 0 5h2m 10.20.54.87 efa <none> <none>
goraslog-service-rvjsj 1/1 Running 0 5h3m 10.20.54.87 efa <none> <none>
gofabric-service-6c4qs 1/1 Running 0 5h3m 10.42.194.76 efa <none> <none>
gopolicy-service-g78bh 1/1 Running 0 5h3m 10.42.194.77 efa <none> <none>
gosnmp-service-x86sn 1/1 Running 0 5h1m 10.20.54.87 efa <none> <none>
$ systemctl status hostauth.service
hostauth.service - OS Auth Service
Loaded: loaded (/lib/systemd/system/hostauth.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2020-04-23 07:56:20 UTC; 23 h ago
Main PID: 23839 (hostauth)
Tasks: 5
CGroup: /system.slice/hostauth.service
23839 /apps/bin/hostauth
Apr 23 07:56:20 tpvm2 systemd[1]: Started OS Auth Service
