Prepare Small Data Center Fabric for Centralized Routing
You can use the following command to create a small data center (non-Clos) fabric containing border-leaf devices, which can be used for centralized routing.
Tip
If any devices in a fabric are in "admin-down" state, use of the following commands in that same fabric will not add or delete devices in the fabric: efa fabric device add-bulk and efa fabric device remove.efa fabric create --name <fabric-name> --type non-clos efa fabric device add-bulk --name <fabric-name> --rack <leaf-rack-name> --ip <leaf-ip-pair> --border-leaf-rack <bl-rack-name> --border-leaf-ip <bl-ip-pair> efa fabric configure --name <fabric-name>
