This provides the common fields of the DEVICE_EVENTS object that would be sent over the Syslog channel.
| Field | SD-ID (Structured Data ID) | Example | Description |
| <###> | N/A |
                             190 =(23 * 8) + 6
                             Priority Value: (Syslog Classifier * 8) + Syslog Informational message
 Syslog Classifier: 23 Local7
 Syslog Severity: 6 Informational: informational messages  |
| Version | N/A | 1 | Version of syslog message |
| Timestamp | N/A | 2022-10-12T09:54:28.506827-07:00 | Timestamp of syslog message |
| Hostname | N/A | GE-SH | Hostname of EFA |
| App Name | N/A | - | Application generating syslog alerts. Possible values |
| Proc ID | N/A | - | Process ID |
| Msg ID | N/A | DCM-1116 | Raslog ID of the device event |
| Sequence ID | meta | 49051 | Tracks the sequence in which messages are submitted to the syslog transport per device. |
| IP | origin | 10.20.30.40 | IP address (of the Device) |
| Enterprise ID | origin | 1588 | Device‘s Enterprise ID |
| BOMText | N/A | System initialization is complete. SLX-OS is ready to handle all commands. | (Byte Order Mask) Textual description of the Alert |
Map DEVICE_EVENTS to RELP/Syslog fields (RFC-5424)
<190>1 2022-10-12T09:54:28.506827-07:00 GE-SH - - DCM-1116 [meta sequenceId="49051"] [origin ip="10.24.0.56" enterpriseId="1588"] [log@1588 value="RASLOG"] [timestamp@1588 value="2022-10-12T16:54:24.395333"] [msgid@1588 value="DCM-1116"] [attr@1588 value=" WWN 10:00:00:04:96:b8:37:5b"] [severity@1588 value="INFO"] [swname@1588 value="SLX9740-80C"] BOMSystem initialization is complete. SLX-OS is ready to handle all commands.
