To enable external connectivity, you can configure the
send-community attribute when you create or update the BGP peer
(IPv4 and IPv6).
efa tenant service bgp peer create --name <bgp-peer-name> --tenant <tenant-name>
--ipv4-uc-nbr <device-ip,vrf-name:neighbor-ip,remote-asn>
--ipv4-uc-nbr-bfd <device-ip,vrf-name:neighbor-ip,true|false>
--ipv4-uc-nbr-send-community <device-ip,vrf-name:neighbor-ip,
all|both|extended|large|standard|large-and-standard|large-and-extended>
--ipv6-uc-nbr-send-community <device-ip,vrf-name:neighbor-ip,
efa tenant service bgp peer update --name <bgp-peer-name> --tenant <tenant-name>
--operation peer-add
ipv4-uc-nbr-send-community and
ipv6-uc-nbr-send-community are an optional
attributes.Example
efa tenant service bgp peer create --name ten1bgppeer1 --tenant ten1
--ipv4-uc-nbr 10.20.246.15,ten1vrf1:10.20.30.40,50000
--ipv4-uc-nbr-bfd 10.20.246.15,ten1vrf1:10.20.30.40,true
--ipv4-uc-nbr-send-community 10.20.246.15,ten1vrf1:10.20.30.40,all
--ipv4-uc-nbr 10.20.246.16,ten1vrf1:10.20.30.40,50000
--ipv4-uc-nbr-bfd 10.20.246.16,ten1vrf1:10.20.30.40,true
--ipv4-uc-nbr-send-community 10.20.246.16,ten1vrf1:10.20.30.40,both
efa tenant service bgp peer update --name ten1bgppeer1 --tenant ten1
--ipv4-uc-nbr 10.20.246.15,ten1vrf1:10.20.30.50,50000
--ipv4-uc-nbr-bfd 10.20.246.15,ten1vrf1:10.20.30.50,true
--ipv4-uc-nbr-send-community 10.20.246.15,ten1vrf1:10.20.30.50,standard
--ipv4-uc-nbr 10.20.246.16,ten1vrf1:10.20.30.50,50000
--ipv4-uc-nbr-bfd 10.20.246.16,ten1vrf1:10.20.30.50,true
--ipv4-uc-nbr-send-community 10.20.246.16,ten1vrf1:10.20.30.50,extended
efa tenant service bgp peer show --detail
Tenant : ten1
State : bs-state-created
Description :
Static Peer
Device IP : 10.20.246.15
VRF : ten1vrf1
AFI : ipv4
SAFI : unicast
Remote IP : 10.20.30.40
Remote ASN : 50000
Next Hop Self : false
Update Source IP :
BFD Enabled : true
BFD Interval : 0
BFD Rx : 0
BFD Multiplier : 0
Default Originate:
Default Originate
Route Map :
Send Community : all
Dev State : provisioned
App State : cfg-in-sync
VRF : ten1vrf1
AFI : ipv4
SAFI : unicast
Remote IP : 10.20.30.50
Remote ASN : 50000
Update Source IP :
BFD Enabled : true
BFD Interval : 0
BFD Rx : 0
BFD Multiplier : 0
Default Originate: false
Default Originate
Route Map :
Send Community : standard
Device IP : 10.20.246.16
VRF : ten1vrf1
AFI : ipv4
SAFI : unicast
Remote ASN : 50000
Update Source IP :
BFD Enabled : true
BFD Interval : 0
BFD Rx : 0
BFD Multiplier : 0
Default Originate
Route Map :
Send Community : both
VRF : ten1vrf1
AFI : ipv4
SAFI : unicast
Remote ASN : 50000
Update Source IP :
BFD Enabled : true
BFD Interval : 0
BFD Rx : 0
BFD Multiplier : 0
Default Originate
Route Map :
Send Community : extended
Dynamic Peer
0 Records
Rack1-Device1# show running-config router bgp router bgp local-as 4200000000 capability as4-enable fast-external-fallover neighbor 10.20.20.4 remote-as 4200000000 neighbor 10.20.20.4 next-hop-self address-family ipv4 unicast network 172.31.254.46/32 network 172.31.254.123/32 maximum-paths 8 graceful-restart ! address-family ipv4 unicast vrf ten1vrf1 redistribute connected neighbor 10.20.30.40 remote-as 50000 neighbor 10.20.30.40 send-community all neighbor 10.20.30.40 bfd neighbor 10.20.30.50 remote-as 50000 neighbor 10.20.30.50 send-community standard neighbor 10.20.30.50 bfd maximum-paths 8 ! address-family ipv6 unicast ! address-family ipv6 unicast vrf ten1vrf1 redistribute connected maximum-paths 8 ! address-family l2vpn evpn graceful-restart ! ! |
Rack1-Device2# show running-config router bgp router bgp local-as 4200000000 capability as4-enable fast-external-fallover neighbor 10.20.20.5 remote-as 4200000000 neighbor 10.20.20.5 next-hop-self address-family ipv4 unicast network 172.31.254.46/32 network 172.31.254.176/32 maximum-paths 8 graceful-restart ! address-family ipv4 unicast vrf ten1vrf1 redistribute connected neighbor 10.20.30.40 remote-as 50000 neighbor 10.20.30.40 send-community both neighbor 10.20.30.40 bfd neighbor 10.20.30.50 remote-as 50000 neighbor 10.20.30.50 send-community extended neighbor 10.20.30.50 bfd maximum-paths 8 ! address-family ipv6 unicast ! address-family ipv6 unicast vrf ten1vrf1 redistribute connected maximum-paths 8 ! address-family l2vpn evpn graceful-restart ! ! |
