Log in to EFA
Use of the EFA command line requires a valid, logged-in user.
Verify the status of the EFA deployment using one of the following methods.
- Run the SLX show efa status command.
- Run the EFA efactl status script (or the efa status command, as an alternative).
Log in to EFA.
$ efa login --username <username> Password: <password>
The <username> variable is optional. If you do not provide a user name, log-in defaults to the current (Unix) user.With a successful log-in, the command prompt shows the logged-in user in green text. If the log-in is not successful, the command prompt is displayed in red text. - To log out of EFA, run the efa logout command.
