The layer3-extension is enabled by default for the Distributed VRF instantiated by EFA and you cannot disable it. The layer3-extension is disabled by default for the Centralized VRF instantiated by EFA and you cannot enable it.
When the layer3-extension is enabled, the following configurations are pushed by EFA:
efa tenant vrf create --tenant <tenant-name> --name <vrf-name>
--layer3-extension-enable {true | false}
efa tenant vrf create --tenant "t1" --name "v1" --routing-type "distributed" --rt-type import --rt 101:101 --rt-type export --rt 101:101
efa tenant vrf show --name v1 --tenant t1 –detail
Tenant: : t1
Routing Type : distributed
Centralized Routers :
Enable Layer3 Extension : true
Redistribute : connected
Max Path : 8
Local Asn :
L3VNI :
EVPN IRB BD :
EVPN IRB VE :
BR VNI :
BR BD :
BR VE :
RH Max Path :
Enable RH ECMP : false
Enable Graceful Restart : false
Route Target :
Static Route :
Static Route BFD :
Network Route Address :
Static Network :
Aggregate Address :
VRF Type :
State : vrf-created
Dev State : not-provisioned
App State : cfg-ready
efa tenant epg create --name epg1 --tenant t1 --switchport-mode trunk –port 10.20.246.15[0/1] --vrf v1 --switchport-native-vlan 10 --ctag-range 10 --anycast-ip 10:10.10.12.1/24
Tenant : t1
Max Path : 8
Local Asn :
L3VNI : 10111
EVPN IRB BD : 4096
EVPN IRB VE : 8192
BR VNI : 10110
BR BD : 4095
BR VE : 8191
RH Max Path :
Route Target : import 101:101
: export 101:101
Static Route :
Static Route BFD :
Static Network :
Aggregate Address :
VRF Type :
State : vrf-device-created
Dev State : provisioned
App State : cfg-in-sync
Rack1-Device1# show running-config vrf v1 vrf v1 rd 172.31.254.19:1 evpn irb ve 8192 cluster-gateway address-family ipv4 unicast route-target export 101:101 evpn route-target import 101:101 evpn ! address-family ipv6 unicast route-target export 101:101 evpn route-target import 101:101 evpn ! ! |
Rack1-Device2# show running-config vrf v1 vrf v1 rd 172.31.254.20:1 evpn irb ve 8192 cluster-gateway address-family ipv4 unicast route-target export 101:101 evpn route-target import 101:101 evpn ! address-family ipv6 unicast route-target export 101:101 evpn route-target import 101:101 evpn ! ! |
efa tenant vrf create --tenant "t1" --name "v2" --routing-type "centralized"
efa tenant vrf show --name v2 --tenant t1 –detail
Tenant : t1
Routing Type : centralized
Centralized Routers : 10.20.246.15
: 10.20.246.16
Enable Layer3 Extension : false
Max Path : 8
Local Asn :
L3VNI :
EVPN IRB BD :
EVPN IRB VE :
BR VNI :
BR BD :
BR VE :
RH Max Path :
Route Target :
Static Route :
Static Route BFD :
Static Network :
Aggregate Address :
VRF Type :
State : vrf-created
Dev State : not-provisioned|
efa tenant epg create --name epg1 --tenant t1 --switchport-mode trunk –port 10.20.246.15[0/1] --vrf v2 --switchport-native-vlan 10 --ctag-range 10 --anycast-ip 10:10.10.12.1/24
Tenant : t1
: 10.20.246.16
Max Path : 8
Local Asn :
L3VNI :
EVPN IRB BD :
EVPN IRB VE :
BR VNI : 10110
BR BD : 4096
BR VE : 8192
RH Max Path :
: export 101:101
Static Route :
Static Route BFD :
Static Network :
Aggregate Address :
VRF Type :
efa tenant vrf create --tenant "t1" --name "v3" --routing-type "centralized" –-layer3-extension-enable true
efa tenant vrf show --name v3 --tenant t1 –detail
Tenant : t1
: 10.20.246.16
Max Path : 8
Local Asn :
L3VNI :
EVPN IRB BD :
EVPN IRB VE :
BR VNI :
BR BD :
BR VE :
RH Max Path :
Route Target :
Static Route :
Static Route BFD :
Static Network :
Aggregate Address :
VRF Type :
State : vrf-created
efa tenant epg create --name epg1 --tenant t1 --switchport-mode trunk –port 10.20.246.15[0/1] --vrf v3 --switchport-native-vlan 10 --ctag-range 10 --anycast-ip 10:10.10.12.1/24
Tenant : t1
: 10.20.246.16
Max Path : 8
Local Asn :
L3VNI : 10111
EVPN IRB BD : 4096
EVPN IRB VE : 8192
BR VNI : 10110
BR BD : 4095
BR VE : 8191
RH Max Path :
: export 101:101
Static Route :
Static Route BFD :
Static Network :
Aggregate Address :
VRF Type :
Rack1-Device1# show running-config vrf v3 vrf v2 rd 172.31.254.19:1 evpn irb ve 8192 cluster-gateway address-family ipv4 unicast route-target export 101:101 evpn route-target import 101:101 evpn ! address-family ipv6 unicast route-target export 101:101 evpn route-target import 101:101 evpn ! ! |
Rack1-Device2# show running-config vrf v3 vrf v2 rd 172.31.254.20:1 evpn irb ve 8192 cluster-gateway address-family ipv4 unicast route-target export 101:101 evpn route-target import 101:101 evpn ! address-family ipv6 unicast route-target export 101:101 evpn route-target import 101:101 evpn ! ! |
