Configure Shared Tenant, Shared VRF, and Private EPG using Shared VRF
Configure Shared Tenant.
efa tenant create --name <epg-name> --type shared --port <port-list> --vrf-count <num-of-vrfs> --l3-vni-range <l3-vni-range> --vlan-range <vlan-range> --l2-vni-range <l2-vni-range>
Configure Shared VRF under the
ownership of Shared Tenant.
efa tenant vrf create --name <vrf-name> --tenant <shared-tenant-name>
Configure endpoint group (EPG)
under the ownership of Private Tenant using the Shared VRF.
efa tenant epg create --name <epg-name> --tenant <private-tenant> --po <po-list> --switchport-mode <trunk|access> --ctag-range <ctag-range> --anycast-ip <ctag:anycast-ip> --vrf <shared-vrf-owned-by-shared-tenant>
