Configure Local IP for Endpoint Group
You can add or delete local IP address configurations during the following operations:
- Creating endpoint groups (EPGs)
- Adding or deleting CTAG ranges
- Adding or deleting VRFs
The Local IP address is configured on the VE interface assigned to a particular tenant network. You can select different local IP addresses for each device in a tenant network.
To configure local IP when you
create an EPG, run the following commands:
efa tenant epg create --name ten1epg1 --tenant tenant1 --vrf red --switchport-mode trunk --ctag-range 11 --anycast-ip 11:10.10.11.1/24 --port 10.24.80.150[0/1],10.24.80.151[0/1] --local-ip 11,10.24.80.150:11.22.33.41/24 --local-ip 11,10.24.80.151:11.22.34.41/24 efa tenant epg show Name: ten1epg1 Tenant: tenant1 Description: Type: extension Ports : 10.24.80.151[0/1] : 10.24.80.150[0/1] Port Property : switchport mode : trunk : native-vlan-tagging : false NW Policy: ctag-range :11 : vrf : red : vrf-State : vrf-device-created : vrf-Device-State : provisioned : vrf-App-State : cfg-refreshed : l3-vni : 8190 Network Property [Flags : * - Native Vlan] | Ctag | L2-Vni | Anycast-IPv4 | Anycast-IPv6 | BD-name | Local IP (Device-IP->Local-IP) | Dev-state | App-state | +------+--------+--------------+--------------+---------+-------------------------------------+-------------+---------------+ | 11 | 11 |10.10.11.1/24 | | | 10.24.80.151->11.22.34.41/24 | provisioned | cfg-refreshed | | | | | | | | | | | | | | | | 10.24.80.150->11.22.33.41/24 | | |
To delete local IP when you
update an EPG, run the following commands:
efa tenant epg update --name epgv20 --tenant tenant1 --operation local-ip-delete --local-ip 11,10.24.80.150:11.22.33.41/24 efa tenant epg show Name : epgv20 Tenant : t3 Description : Type : l3-hand-off Ports : 10.20.50.209[0/27] POs : posv9 Port Property : switchport mode : trunk : native-vlan-tagging : false NW Policy : ctag-range : 201-202 : vrf : vrfv20 : l3-vni : 5110 Network Property [Flags : * - Native Vlan] +------+--------+--------------+--------------+---------+--------------------------------------+-------------+---------------+ | Ctag | L2-Vni | Anycast-IPv4 | Anycast-IPv6 | BD-name | Local IP (Device-IP->Local-IP) | Dev-state | App-state | +------+--------+--------------+--------------+---------+--------------------------------------+-------------+---------------+ | 201 | 201 | | | | 10.20.50.209->44.4.4.5/24 | provisioned | cfg-in-sync | | | | | | | 4444:44::5/120 | | | | | | | | | 10.20.50.208->44.4.4.4/24 | | | | | | | | | 4444:44::4/120 | | | +------+--------+--------------+--------------+---------+--------------------------------------+-------------+---------------+ | 202 | 202 | | | | 10.20.50.209->44.4.5.5/24 | provisioned | cg-in-sync | | | | | | | 4444:45::5/120 | | | +------+--------+--------------+--------------+---------+--------------------------------------+-------------+---------------+ For 'unstable' entities, run 'efa tenant po/vrf show' for details =================================================================================================================================
To add local IP when you update
efa tenant epg update --name ten1epg1 --tenant tenant1 --operation local-ip-add --local-ip 11,10.24.80.150:11.22.33.41/24 efa tenant epg show Name: ten1epg1 Tenant: tenant1 Description: Type: extension Ports : 10.24.80.151[0/1] : 10.24.80.150[0/1] Port Property : switchport mode : trunk : native-vlan-tagging : false NW Policy: ctag-range :11 : vrf : red : vrf-State : vrf-device-created : vrf-Device-State : provisioned : vrf-App-State : cfg-refreshed : l3-vni : 8190 Network Property [Flags : * - Native Vlan] +------+--------+--------------+--------------+---------+------------------------------------------+-------------+-------------+ | Ctag | L2-Vni | Anycast-IPv4 | Anycast-IPv6 | BD-name | Local IP (Device-IP->Local-IP) | Dev-state | App-state | +------+--------+--------------+--------------+---------+------------------------------------------+-------------+-------------+ | 11 | 11 | | | | 10.24.80.151->11.22.34.41/24 | provisioned | cfg-in-sync | | | | | | | | | | | | | | | | 10.24.80.150->11.22.33.41/24 | | |
