BGP Tables
The following BGP tables help in computing the diffs for the events from the inventory service.
- Router BGP table
- BGP peer group table
- BGP IP address family table
- BGP IP neighbor address table
- BGP EVPN address family table
- BGP EVPN neighbor address table
All BGP tables handle the DB migration so that upgrade from older EFA to newer EFA works.
For more information on the attributes of each table, refer to Database schema section or fabric_schema.sql file.
