Support Matrix
Mirror Type | Mirror Destination Type | Mirror Source | Mirror Destination |
Port-Based | Span | Ethernet | Ethernet |
Port-Based | Span | Port-Channel | Ethernet |
Flow-Based | Span | Ethernet | Ethernet |
Flow-Based | Span | Port-Channel | Ethernet |
Flow-Based | Span |
Local VLAN (with device-ip) |
Ethernet |
Flow-Based | Span |
Global VLAN (without device-ip) |
Ethernet |
Flow-Based | Span |
Local VLAN Range (Supported Range format a-b) |
Ethernet |
Flow-Based | Span |
Global VLAN Range (Supported Range format a-b) |
Ethernet |
np-mac-acl-in | np-mac-acl-out | np-ip-acl-in | np-ip-acl-out | np-ipv6-acl-in | |
L2 VLAN EPG | Supported | Supported | Not Supported | Not Supported | Not Supported |
L3 VLAN EPG | Not Supported | Not Supported | Supported | Supported | Supported |
L2 BD EPG | Not Supported | Not Supported | Not Supported | Not Supported | Not Supported |
L3 BD EPG | Not Supported | Not Supported | Supported | Supported | Supported |
pp-mac-acl-in | pp-mac-acl-out | pp-ip-acl-in | pp-ip-acl-out | pp-ipv6-acl-in | |
Ethernet | Supported | Supported | Supported | Supported | Supported |
Port-Channel | Supported | Not supported, except 9740 | Supported | Supported | Not supported, except 9740 |
- Only SPAN is supported as Destination Type and Mirror Direction support is platform dependent
- Only Ethernet interface is supported as Mirror Destination
- Mirror Destination port value is a mandatory for a mirror source during mirror session create, except for a Global VLAN SPAN
