EFA is shipped with a self-signed certificate that is generated during installation. It is signed by the EFA Intermediate CA certificate. This certificate is used on the following ports:
You can replace server certificate with a third-party certificate acquired through trusted CAs (for example, Verisign or GoDaddy). The third-party certificate must be present in the host device that is running EFA. You can then install it with the following command:
$ efa certificate server --help
Install certificates for EFA
Usage:
efa certificate server [flags]
efa certificate server [command]
Available Commands:
renew Renew certificates for EFA
Flags:
--certificate string Certificate for EFA
--key string Key File for the certificate
--cacert string CA Certificate File
Example:
$ efa certificate server --certificate=my_server.pem --key=my_server.key --cacert=ca-chain.pem Please wait as the certificates are being installed... Certificates were installed! --- Time Elapsed: 30.946303683s ---
The certificate is valid till 3 years from the date of installation. It is regenerated whenever a new multiaccess subinterface is created or deleted from EFA.
Legacy notification is sent to the user if the certificate is going to expire in 30 days. If you do not renew the certificates within 7 days of expiry, a following warning message is displayed on every login to the EFA CLI.
(efa:extreme)extreme@tpvm:/apps/test/certs$ efa login Password: Login successful. Warning: The certificate for 'EFA' will expire on '2022-04-08 14:43:43 +0530 IST'. --- Time Elapsed: 5.532391719s ---EFA server certificate supports the following alerts which effects the health of EFA security subsystem.
For more information, see Fault Management.
To renew the server certificate, use the following command:
(efa:extreme)extreme@tpvm:/apps$ efa certificate server renew Certificate renewal is successful --- Time Elapsed: 33.516064167s ---
CertificateRenewalAlert is raised which changes the health of
the system to green.
