Mirror the traffic from the spine and super spine ports onto the mirror destination port. The provisioning model is inline with the ICL port channel mirroring.
efa tenant epg create --name <epg-name> --tenant <tenant-name>
--type port-profile --port <spine-and-super-spine-mirror-ports>
--pp-ip-acl-in <acl-name> --pp-ip-acl-out <acl-name> --pp-ipv6-acl-in <acl-name>
efa tenant service mirror session create –name <session-name> --tenant <tenant-name>
--source {<device-ip>,<eth | po | vlan>,<if-name>}
--type {<source-device-ip>,<eth | po | vlan>,<source-if-name>:<port-based | flow-based>}
--destination-type {<source-device-ip>,< eth | po | vlan>,<source-if-name>:<span>}
--destination {<source-device-ip>,<eth | po | vlan>,<source-if-name> :
<destination-device-ip>,<eth | po | vlan>,<destination-if-name>
--direction {<source-device-ip>,< eth | po | vlan>,<source-if-name> : <tx | rx | both>}
(efa:root)root@node-2:~# efa tenant show
| Name | Type |VLAN |L2VNI| L3VNI|VRF |Enable| Ports | Mirror Destination |
| | |Range |Range| Range|Count|BD | | Ports |
|tenant11 |shared|100-103| | |10 |false | 10.20.246.1 | 10.20.246.1[0/17-18]|
| | | | | | | | [0/10-11,0/31-32,0/9:1-4] | 10.20.246.1[0/17-18]|
| | | | | | | | 10.20.246.3[0/10-15] | 10.20.246.3[0/1-9] |
| | | | | | | | 10.20.246.4[0/1-15] | |
|tenant111|shared|104-105| | |10 |false | 10.20.246.1 | [0/13-15,0/19, |
| | | | | | | | [0/14-15,0/13:1-4] | 0/12:1-4] |
| | | | | | | | 10.20.246.2 | |
(efa:root)root@node-2:~# efa tenant epg show
| Name | Tenant | Type | Ports |PO |Switch |Native Vlan|Ctag |Vrf| L3Vni| State |
| | | | | |POrt Mode| Tagging |Range| | | |
|epgv421|tenant111|port-profile|10.20.246.2| | | false | | | |epg-with-port-group|
| | | |[0/19] | | | | | | | |
efa tenant service mirror session create --name m2 --tenant "tenant11" --source 10.20.246.1,eth,0/9:1
--type 10.20.246.1,eth,0/9:1:port-based
--destination 10.20.246.1,eth,0/9:1:10.20.246.1,eth,0/17
--destination-type 10.20.246.1,eth,0/9:1:span
--direction 10.20.246.1,eth,0/9:1:rx
efa tenant service mirror session create --name m3 --tenant tenant11 --source 10.20.246.1,eth,0/9:1
--direction 10.20.246.1,eth,0/9:1:tx
efa tenant epg create –name epgv421 –tenant tenant111 --type port-profile
--port 10.20.246.2[0/19] --pp-ipv6-acl-in ext-ipv6-permit-any-mirror-acl
efa tenant service mirror session create --name ms3 --tenant tenant111 --source 10.20.246.2,eth,0/19
--type 10.20.246.2,eth,0/19:flow-based
--destination 10.20.246.2,eth,0/19:10.20.246.2,eth,0/18
--destination-type 10.20.246.2,eth,0/19:span
--direction 10.20.246.2,eth,0/19:tx
efa tenant service mirror session create --name ms4 --tenant tenant111 --source 10.20.246.2,eth,0/19
--direction 10.20.246.2,eth,0/19:rx
10.20.246.1 [PORT-BASED MIRRORING] SLX# show running-config monitor session monitor session 1 source ethernet 0/9:1 destination ethernet 0/17 direction rx ! monitor session 2 source ethernet 0/9:1 destination ethernet 0/17 direction tx ! SLX# show monitor session 1 Session : 1 Type : SPAN Description : [None] State : Enabled Source Interface : Eth 0/9:1 Destination Interface : Eth 0/17 (Down) Direction : rx Type : port-based SLX# show monitor session 2 Session : 2 Type : SPAN Description : [None] State : Enabled Source Interface : Eth 0/9:1 Destination Interface : Eth 0/17 (Down) Direction : tx Type : port-based |
10.20.246.2 [FLOW-BASED MIRRORING] SLX# show running-config ipv6 access-list ipv6 access-list extended ext-ipv6-permit-any-mirror-acl seq 10 permit ipv6 any any mirror ! SLX# show running-config interface ethernet 0/19 interface ethernet 0/19 ip address 10.10.10.1/31 ipv6 access-group ext-ipv6-permit-any-mirror-acl in no shutdown ! SLX# show running-config monitor session monitor session 1 source ethernet 0/19 destination ethernet 0/18 direction tx flow-based ! monitor session 2 source ethernet 0/19 destination ethernet 0/18 direction rx flow-based ! SLX# show monitor session 1 Session : 1 Type : SPAN Description : [None] State : Enabled Source Interface : Eth 0/19 Destination Interface : Eth 0/18 (Down) Direction : tx Type : flow-based SLX# show monitor session 2 Session : 2 Type : SPAN Description : [None] State : Enabled Source Interface : Eth 0/19 Destination Interface : Eth 0/18 (Down) Direction : rx Type : flow-based |
