Webhooks Payload
Webhooks payload is a key-value pair which can hold information for all notification types. Some fields are common and some are applicable only to particular notification types. Webhooks send only the fault alerts introduced in EFA 3.1.0.
Following table summarizes the supported key-value pairs:
Payload Fields APP_EVENTS (Task Events) DEVICE_EVENTS (SLX Raslog Events) APP_ALERTS (Fault-Alerts Only)
type ✓ (Task) ✓ (Event) ✓ (Alert)
timestamp ✓ ✓ ✓
severity ✓ ✓ ✓
message ✓ ✓ ✓
application ✓ ✓ ✓
source_ip ✕ ✓ ✓
device_ip ✓ ✓ ✕
message_id ✕ ✓ ✕
task ✓ ✕ ✕
scope ✓ ✕ ✕
status ✓ ✕ ✕
username ✓ ✕ ✕
sequence_id ✕ ✕ ✓
alert_id ✕ ✕ ✓
resource ✕ ✕ ✓
alarm_type ✕ ✕ ✓
alarm_cause ✕ ✕ ✓
alert_data ✕ ✕ ✓
(This will have nested key-value pairs with alert specific data)
