Change the Default Gateway of a TPVM
Use this procedure to change the default gateway of a TPVM.​ This procedure has no impact on the functioning of EFA high-availability mode.
  • The gateway IP address must be in the same subnet as one of the subinterfaces that are created in EFA.
  • Perform this procedure on both nodes where EFA is deployed, to avoid a loss of EFA functionality.
  • Perform this procedure with caution. EFA and SLX-OS do not validate reachability of the gateway during this operation.
  • Vital services, such as DNS, NTP, and LDAP, must be reachable from the new gateway.
  1. Add static IP addresses to the subinterface.
    You can assign a maximum of one pair of static IP addresses. Only one subinterface at a time can have static IP addresses.
    efa mgmt subinterface staticip --name <sub-int-name> --ip1 <ip-addr>
    --ip2 <ip-addr>
  2. Change the gateway of the standby TPVM.
    efa inventory device execute-cli --ip <standby-slx-ipaddr>
    --command "tpvm TPVM,interface management ip <standby-tpvm-ipaddr>
    gw <new-gateway-ipaddr>" --config
  3. Change the gateway of the active TPVM.
    efa inventory device execute-cli --ip <active-slx-ipaddr>
    --command "tpvm TPVM,interface management ip <active-tpvm-ipaddr>
