Edit Fabric Settings
Updated Fabric Settings
and corresponding modification codes are
displayed.efa fabric show output: ... Updated Fabric Settings: BGP-LL FABRIC SETTING: BGPLL - BGP Dynamic Peer Listen Limit, BGP-MD5 - BGP MD5 Password , BFD-RX - Bfd Rx Timer, BFD-TX - Bfd Tx Timer, BFD-MULTIPLIER - Bfd Timer,BFD-ENABLE - Enable Bfd, BGP-MULTIHOP - BGP ebgp multihop, P2PLR - Point-to-Point Link Range, MCTLR - MCT Link Range, LOIP - Loopback IP Range..
- Changes does not reflect in
app-state
,drc-drift
, anddrc-reconcile show
outputs. - Changes are pushed into SLX only after you run the efa fabric configure command.
- After successful execution of the efa fabric configure command, the efa fabric show command clears the fabric status and fabric settings updated codes.
Edit Fabric IP Range Settings
- You can edit the following active fabric settings even after the devices are
added in fabric:
--loopback-ip-range
--p2p-link-range
-mctlink-ip-range
- You can generate increased IP or
IP-Pair and update them in the available IP-Pool. There are no updates to the
used-IP pair. For example,
- Old IP range: 10.10.10.1/24
- New IP range: 10.10.10.1/23
- Increased IP range: 10.10.10.1/23 - 10.10.10.1/24
- The increased IP addresses are available for use when new devices are added into the fabric.
- You can edit
l
oopback-ip-range
,p2p-link-range
, andmctlink-ip-range
settings. Ensure that the prefix mask length is lower than the configured prefix mask length value within the same network.‘efa fabric show‘ output sample: ... Fabric Name: fs, Fabric Description: , Fabric Type: non-clos, Fabric Status: settings-updated Updated Fabric Settings: MCTLR,P2PLR,LOIP FABRIC SETTING: BGPLL - BGP Dynamic Peer Listen Limit, BGP-MD5 - BGP MD5 Password , BFD-RX - Bfd Rx Timer, BFD-TX - Bfd Tx Timer, BFD-MULTIPLIER - Bfd Timer,BFD-ENABLE - Enable Bfd, BGP-MULTIHOP - BGP ebgp multihop, P2PLR - Point-to-Point Link Range, MCTLR - MCT Link Range, LOIP - Loopback IP Range
Edit Fabric BFD Settings
added in fabric:
--bfd-enable <yes|no>
--bfd-tx <val>
---bfd-rx <val>
--bfd-multiplier<val>
‘efa fabric show‘ output sample: ... Fabric Name: fs, Fabric Description: , Fabric Stage: 3, Fabric Type: clos, Fabric Status: settings-updated Updated Fabric Settings: BFD-ENABLE,BFD-TX,BFD-RX,BFD-MULTIPLIER FABRIC SETTING: BGPLL - BGP Dynamic Peer Listen Limit, BGP-MD5 - BGP MD5 Password , BFD-RX - Bfd Rx Timer, BFD-TX - Bfd Tx Timer, BFD-MULTIPLIER - Bfd Timer,BFD-ENABLE - Enable Bfd, BGP-MULTIHOP - BGP ebgp multihop, P2PLR - Point-to-Point Link Range, MCTLR - MCT Link Range, LOIP - Loopback IP Range
- The efa fabric configure command generates BFD recipe for
router BGP
,interface links
,MCT port-channel interfaces
, and pushes the configuration to the SLX devices.
Fabric Settings in Active Fabric: Small Data Center Fabric
Cannot be Updated | Can be Updated | Invalid Settings for Small Data Center Fabric |
--backup-routing-ipv6-range |
--bgp-dynamic-peer-listen-limit |
--default-mdtgroup |
Fabric Settings in Active Fabric: Clos Fabric
Cannot be Updated | Can be Updated | Invalid Settings for Clos Fabric |
--rack-overlay-ebgp-peer-group |
