Shared VRF and Router
EFA provides a provisioning model to support sharing of VRF or Router across multiple tenants. Following models are supported:
- Inter-POD (Inter-Tenant) routing (Tenant1 routing to Tenant2 and vice versa)
- Multiple tenants accessing a shared resource (for example, storage)
- Multiple tenants using a shared VRF for l3-hand-off
Entities (VRFs) created by the shared tenant are available for the use by all the Private Tenants.
