EFA 3.1.0 introduces RFC5424 format for all notification types. Using RFC5424 flag at the subscriber level, syslog subscribers can choose the message format.
Following table summarizes the effect of the RFC5424 flag on syslog subscribers:
| RFC-5424 | Device Events | App Events | App Alerts |
| Enabled | RFC-5424 format | RFC-5424 format | RFC-5424 format (Only fault-alerts will be sent) |
| Disabled |
Legacy format |
Legacy format |
Legacy format (Only legacy alerts which exists prior to 3.1.0 will be sent) |
CLI changes
(efa:root)root@pasu-dev-server:~/build/efa# efa notification subscribers add-syslog-relp --help
Register a new RELP syslog subscriber to the notification service.
Usage:
efa notification subscribers add-syslog-relp [flags]
Flags:
--address string Address for syslog server in the format host:port (Required), Default port: 514
--insecure Perform insecure SSL connection and transfers. (Optional)
--cacert string Local path to the cacert pem file for SSL verification. (Optional, required if not insecure)
--conn-timeout int Timeout to open a connection to the server (Optional) (default 10)
--filter strings Comma separated filter values. Possible values are "DEVICE_EVENTS" - RAS/syslog events from devices, "APP_ALERTS" - fault alerts from application, "APP_EVENTS" - task events from application. If no filters are provided it means all types. E.g. --filters DEVICE_EVENTS,APP_ALERTS,APP_EVENTS. (Optional)
--rfc5424 Enable RFC5424 message format for syslog subscribers (Optional) (default: non-RFC5424 format)
--- Time Elapsed: 2.756476ms ---
#efa notification subscribers add-syslog-relp --address 127.0.0.1:1601 --insecure --rfc5424
Successfully registered subscriber.
|attribute |value |
|id |7 |
|handler |relp |
|endpoint |134.141.21.190:1601 |
|config |{"cacert":"","conn-timeout":10,"filters":[],"insecure":true,"rfc5424":true}|
Notification Subscriber ID=7
