EFA does not provision reload-delay 90 configuration on Cluster Edge Port (CEP) interfaces.
EFA instead provisions cluster-track configuration on CEP interfaces when the CEP is
configured as a member of an EPG (endpoint group) during the creation or updating of
endpoint groups.
During upgrade from EFA
2.3.0 to 2.4.0 and above, EFA marks all the CEPs with
the intended cluster-track configuration and shows it as configuration drift. On
reconciliation of the drift, EFA pushes the cluster-track
configuration to the CEP ports. Before the cluster-track
configuration push, EFA automatically removes the
reload-delay
configuration from the CEP ports.
# efa tenant po create --name po11 --tenant tenant1 –speed 10Gbps --negotiation active --port 10.24.80.134[0/15] => CEP # efa tenant po create --name po12 -–tenant tenant1 -–speed 10Gbps --negotiation active -–port 10.24.80.134[0/25],10.24.80.135[0/25] => CCEP # efa tenant epg create --name ten1epg1 --tenant tenant1 --switchport-mode trunk --ctag-range 1001 --port 10.24.80.134[0/35] --po po11,po12
