Drift and Reconcile
EFA supports drift and reconcile (DRC) of a configuration at device level. A single device configuration is compared with EFA. If there is a drift in the configuration, it is conciled. EFA provides APIs to initiate drift and reconcile requests. Use the EFA command efa inventory drift-reconcile execute to run a manual DRC.
Drift and reconcile is also activated during the following operations:
- Switch replacement and RMA
- After the reboot of a device in maintenance mode
- Device firmware-download with “drc” flag
Drift and reconcile operations are run in parallel across all devices in the fabric. It ensures that the multiple DRC operations that take place during fabric-wide firmware-download (FWDL) or reboot of multiple devices together, run in parallel, and hence, reduce the overall maintenance window.
If maintenance-mode-enable on reboot is not set on the devices, Data Consistency is not guaranteed and drift and reconciliation operation is skipped.
When any attribute under "router bgp" is drifted, EFA also reconciles the cluster configuration to ensure that the BGP neighbors of MCT are reconciled, and this shows up as cluster reconciled success in addition to routerbgp.
