View Fabric Details
You can use several commands to view the details of topologies and configuration in your fabric.
Command | Description |
efa fabric topology show overlay |
Shows the overlay (VxLAN tunnels) connectivity of devices in a fabric. |
efa fabric topology show physical |
Shows the physical topology (LLDP neighbors) connectivity of devices in a fabric. |
efa fabric topology show underlay |
Shows the underlay (BGP neighbors) connectivity of devices in a fabric. |
efa fabric show |
Displays fabric details. |
efa fabric show-config |
Displays fabric configuration details for the specified role (leaf, spine, super-spine, border leaf) or IP address. |
efa fabric show summary |
Displays a summary of all fabrics or of the specified fabric. |
The following is an example of output from the efa fabric topology show overlay command.
efa fabric topology show overlay --name fabric1 +------------+---------------------------+---------------------------+----------------+---------------+-------------+------------+---------- | OVERLAY | SOURCE LEAF IP | DESTINATION LEAF IP | SOURCE VTEP IP | DESTINATION | OVERLAY | OVERLAY | OVERLAY ECAP TYPE VTEP IP ADMIN STATE OPER STATE BFD STATE +------------+---------------------------+---------------------------+----------------+---------------+-------------+------------+---------- | vxlan | 10.25.225.11,10.25.225.46 | 10.24.85.76,10.24.85.74 | 172.31.254.86 | 172.31.254.81 | up | up | down | vxlan | 10.25.225.11,10.25.225.46 | 10.24.80.134,10.24.80.135 | 172.31.254.86 | 172.31.254.83 | up | up | down | vxlan | 10.24.85.76,10.24.85.74 | 10.25.225.11,10.25.225.46 | 172.31.254.81 | 172.31.254.86 | up | up | down | vxlan | 10.24.85.76,10.24.85.74 | 10.24.80.134,10.24.80.135 | 172.31.254.81 | 172.31.254.83 | up | up | down | vxlan | 10.24.80.134,10.24.80.135 | 10.25.225.11,10.25.225.46 | 172.31.254.83 | 172.31.254.86 | up | up | down | vxlan | 10.24.80.134,10.24.80.135 | 10.24.85.76,10.24.85.74 | 172.31.254.83 | 172.31.254.81 | up | up | down +------------+---------------------------+---------------------------+----------------+---------------+-------------+------------+----------
The following is an example of output from the efa fabric show command.
efa fabric topology show overlay --name fabric1 +--------------+-------+-------------+-----------+------+--------------+-------------+------------+----------+------+------- | IP ADDRESS | RACK | HOST NAME | ASN | ROLE | DEVICE STATE | APP STATE | CONFIG | PENDING | VTLB | LB ID GEN REASON CONFIGS ID +--------------+-------+-------------+-----------+------+--------------+-------------+------------+----------+------+------- | 10.24.51.131 | rack2 | Freedom-07 | 4200000001| leaf | provisioned | cfg in-sync | NA | NA | 2 | 1 | 10.25.255.58 | rack2 | Freedom-04 | 4200000001| leaf | provisioned | cfg in-sync | NA | NA | 2 | 1 | 10.24.51.135 | rack1 | Freedom-06 | 4200000000| leaf | provisioned | cfg in-sync | NA | NA | 2 | 1 | 10.24.48.131 | rack1 | Freedom-05 | 4200000002| leaf | provisioned | cfg in-sync | NA | NA | 2 | 1
